Frosted Glass
https://www.daz3d.com/forums/uploads/FileUpload/24/e48647b9becf548c7273fb4bddd76a.jpg
Someone can help me create or find a shader/material preset to obtain the effect of that image?
It's related to carrara but Carrara's presets doesn't work in DAZ Studio!
  • Oso3DOso3D Posts: 15,116
    For 3DL or Iray?
  • ImagoImago Posts: 5,782
    3DLight... Sorry, I forgot to add that detail! *blushes*
  • FishtalesFishtales Posts: 6,233
    There is an Iray shader Glass-Solid-Frosted-Clear which comes with the Iray default shaders.
    The first image is a plane with the shader added and untouched. The second one I lowered the Glossy Roughness to .35.
    1496 x 997 - 452K
    1496 x 997 - 367K
    Looks good enough, but it's Iray... And I need it in 3DLight...
    I could try to convert it with that new Iray to 3DL conversion script but seems to not worl for me, I don't know if I'm doing something wrong with it!
    Yeah, the conversion script won't handle complex stuff with refraction/SSS/etc.
    And... huh. I don't see anything like 'refraction blur' from any of the normal 3DL shaders I have (US, US2, AoA SSS, plus normal). Weird.
    Seems an obvious lapse.
    This refraction blur sounds like the missing piece... I haven't mastered shaders yet, but I can follow instructions and learn...
    How can I set up a simple shader that activates that function?
    I have no idea if it even exists. You should check out the 3delight lab thread on Common (I don't have a link handy)
    I'll try there then... Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,390
    You could try mapping the index of refelection with a noise map (or procedural). What I did once, a long tiem back, was increase the sample cone setting on the refraction brick (which meant stuff close to the glass was sharp and more distant stuff blurred), but I think that was DS3 and the bricks are somewhat changed in 4.
    I'll give it a try, thanks!
    The main problem is that the shader builder and similar systems aren't very user friendly!
    (almost spits out his drink)
    Yeah, that's... an understatement.
