Texture Animator Pro help anyone?
trip citrus
Draagonstorm's Pro version has a short video with no real "how to's" on setting up scenes like the first version of the script, there were many videos on the earlier version on how everything worked, it also had a pane tab called texture animator which I'm assuming this newer version does not?
I've got an animated scene where I'm attempting to add an image sequence (from a video already converted to .jpg files) to a surface (TV screen) and I've followed the brief steps taken in the short video
but it only adds the first .jpg which does not animate, I've got 2 tabs under Utilities that have in tab 1 (animated textures pro, preview off, preview on, refresh animated properties), and tab 2-resources with (animate textures, getanimated textures) that don't seem to do anything when double clicked.
The read me has no dedicated .pdf user's guide and there is only the one video on use that isn't answering the basics like how to make this script work.
I'm loading my scene, 900 frames, there's TV set a camera is making a dolly move towards, I have the screen selected in surfaces, I add the 0000.jpg file under image layer editor using the alpha channel and what I get is that single image that stays on the screen for the entire 900 frames, no movement even though the "point to" folder contains the video for the TV sequenced out to 900 frames as well.
Has anyone else figured out how to use this plug in or can point me in the right direction for application? I've exhausted the search terms here, google, youtube, etc....a lot on the first plug in, nada on this script.
