Need Tester to Resolve Rigging issue.
Td3d
I have built a couple of guitar props and used the same Tremelo on both guitars. I rigged the Tremelo on the LP model and the Arm moves fine with the slider. But on the other guitar the Arm has a delay when the slider is used for it. I cannot work it out and am under a bit of preasure to have this thing completed and working asap. Would anyone with some rigging experience like to have a version of both these guitars to download, to keep, look at and see what the problem with the arm is, more importantly resolve it? I have tried everything and can't get rid of that delayed action. ie move slider, let go of slider with mouse, then the arm decides to move. after it is moved, the arm will zero between fine adjustments. Driving me nuts. This guitar is ready for market all but this annoying problem.
Thanks if anyone can help out. I can offer a link to my files if it is allowed. I am extremely anxious about what I can and can't ask or offer. These are my guitar props. I just need help :)
This got solved by a friend and some good info. I will post the fix incase someone is having the same issues.
Thank you for that tip.
- Pick Tool setting, choose "Node WM brush"
- Pick the tremolo bone in scene tab, then active WM should be seen in the WM tab
- Add a general Weight map
- Copy the current/active WM (right-clic with mouse, for "copy selected")
- Paste it on the General Weight map
