Saving Geo Shells for Props?
Okay. I've recently been experimenting with geoshells. I know how to generate them (a few clicks of the mouse button, easy), and I understand that saving geoshells for figures is simple enough (hust Save As > Wearable Present). However, I've run into a problem with props.
So say that I've created a geoshell for a prop of some sort. How do I save that shell so that it hooks up with the prop? Do I have to save the prop and shell in one package? And if so, how?
  • Richard HaseltineRichard Haseltine Posts: 112,037
    Wearables require a figure as the parent, so you'd either need to turn your prop into a figure - and save as an asset - before saving the wearable or you'd to use a Scene Subset and load both together.
