Viewport switched to camera. Please could someone advise?
Hi guys,
i hope someone could help me here. My viewport in daz studio has switched as though I'm looking through the camera with a ratio visible in the corner. I've lost my navigation hockey's too using my tablet so I am unable to navigate properly. How can I return it to the default viewport so I can use daz3d as normal.
Thank you for any help
gregg
  • TheKDTheKD Posts: 2,711
    edited April 2017
    Try going to window menu, workspace, layout and select a different layout, then switch back to the one you prefer. If that doesn't fix it, go to window, style select style, switch to another, then switch back. That usually fixes it when I mess up my daz studio.
    Post edited by TheKD on
  • Richard HaseltineRichard Haseltine Posts: 111,609
    The Aspect frame can be switched on and off from the Viewport option menu - the lined button at top-right, or right-click on the tab.
    The default keyboard shortcut for WASD navigation, if that is what you mean, is shift K.
  • Cool, I found the switch to turn it off in the top right menu above the viewport . Thanks though :-)
