Reorganize Shaping Dials
TheKDTheKD Posts: 2,711
Sick of looking at the mess that is the shaping panel. How can I change it to my liking? For example I want to move all shapes for ears, into the ears section.
Post edited by TheKD on
  • Richard HaseltineRichard Haseltine Posts: 112,059
    Click the gear icon the slider, open Parameter Settings, and edit the Path - if you use the Parametrs pane and put it in Edit mode, from the right-click menu, you can select multiple properties at once and edit via the right-click menu. SAving can be an issue as if you save back to morph assets any product update will overwrite your changes - you can save your version as a scene, or a Character preset, possibly other presets would work but I can't recall.
  • TheKDTheKD Posts: 2,711
    I will have to redo the whole genesis 3 anytime I need an update? Or just that updated set?
    The grouping is saved with the morph, so if you save your version over the original and there's an update to the product the moprh comes with you will get the original (or updated by the venmdor) grouping back. If you save as a scene or preset that won't happen, but you also won't get any benefits from updates to the product.
    edited April 2017
    Bah nevermind, guess I am gonna have to live with the mess and hope genesis 10 gets more strict with the dial placements.
