Skin tone for FWSA Zarina
Is there a somewhat simple way to lighten the skin tone for FWSA Zarina? I do not want to lighen it much, just a little bit. i would like to create contrast between several characters using the same texture in the same scene.
Thanks
  • barbultbarbult Posts: 27,500
    Try lowering the Translucency Strength.
  • snowsnow77snowsnow77 Posts: 101
    I lowered it to zero, didnt seem to change anything.
  • nicsttnicstt Posts: 11,715
    edited April 2017
    Using IRAY
    I don't have the character; it depends on what the textures are like, and how the shaders are set up.
    Two identical characters; on the right one (as you look at the pic),
    select skin/lips/nails
    if scatter and transmit is specified (and maybe if not)
    adjust the translucency colour.
    You'll see I adjust the colour again for sss-2, and it is only slightly different.
    This was an easy one; some I create my own SSS textures, and sometimes other textures too to get the look I'm after.
    If what I've suggested doesn't work, try adjusting the base colour by very small amounts, I tend to avoid that, but sometimes I prefer what I get by doing it.
    1274 x 758 - 130K
    1338 x 779 - 128K
    Post edited by nicstt on
