Corrupted Base Figure (Genesis 2 Female)
At some point, my brilliant phlying phingers did something that corrupted the Genesis 2 Female base figure.  Instead of the 'normal' G2F figure, I have a G2F infused with the morphs for another figure (in this case, "Dionne" from most-digital-creations).
I can 'recover' the base figure by zeroing out the figure, or going into the shaping tab and setting all Dionne-morph dials to '0'.
Saving as a character preset doesn't "replace" the base figure so that next time I select the G2F figure, it's back to the corrupted figure again.
My thought is that I'll have to uninstall the Genesis 2 Starter Essentionals, re-download the package and install it again.  (Un install from DIM; remove the associated files from my computer; download a fresh package from DAZ; reinstall with DIM).
Any ideas on an 'easier' way?
THanks!
Felix/FFDS
  • DigiDotzDigiDotz Posts: 515
    edited April 2017
    Try temporaraly re-naming deleting the Dionne morph folder and load again. ignore errors and see if shape is normal. If so, the Dionne morphs may have somehow been set to default above zero - somewhere in my library>data>Daz3d>Genesis 2>Female>morphs>(mostDigital?)
    -could be a few things though so just a guess..
    Post edited by DigiDotz on
  • WandWWandW Posts: 2,907
    Uninstalling from DIM should remove the files, but I would simply try replacing the relevant Genesis 2 base  DUF file (/People/Genesis 2 Female/Genesis 2 Base Female.duf) from the .zip and see if that fixes it.  You can grab the .zip here if you are logged into the store.....
    https://www.daz3d.com/downloader/customer/files/prod/16280
  • FelixFFDSFelixFFDS Posts: 42
    @DigiDotz / @WandW - thanks for two very interesting ideas!  I'll definitely try them out when I get home tonight!
    I followed through with what I believed to be the least 'disruptive' method - as suggested by DigiDotz.  Basically, I removed the morphs (and somehow, the DSON files also affected it.  FINALLY I have a "real" G2F!
    I think I will, at some point, reload the G2F from the zip file.
    Thanks again to both of you!!
