Big Cat Mouth Texdture Is Missing
Greybro
I've tried this on 2 different installs on two different machines. It appears that the teeth and mouth texture on all the big cats are missing. Can someone point me to the fix.
Please advise.
1130 x 792 - 490K
They use a cuastom shader which only 'appears' when rendered with 3Delight.
Well that sucks! But actually I was rendering with 3Delight in this case and it still came out blank.
You loaded the preset "Breeds/Lion with Dark Mane"? What shader appears on the Inner Mouth surface (upper left of Surfaces pane)?
Looking in the texture directory, Big Cat 2 has a diffuse mouth/tongue texture -- and ONLY a diffuse, which is odd -- but no teeth texture. I'm doing a set of renders right now, so I can't tell whether or not they actually apply with any texture set.
The teeth have a shader called Chrome, Tongue is Material_1
The textures appear to be assigned and they are in the textures directory. They just don't render.
It does sound liek youare using Iray - as most of the other textures are DAZ Studio Default or omUbserSurface (tongue, eyes and whiskers being hte main custom surafces) I'd expect teh conversion to have a resonable stab at those, and various degrees of success (mainly failure!) for the tongue, teeth, eyes and whiskers, etc. This si what he loosk liek for me, using Iray
