Fitting outfit to character
Earth BalmEarth Balm Posts: 27
I recently bought Elven for Genesis 3 but cannot get the costume to fit either the Genesis 3 default figure or Victoria 4. Could anybody please advise me on how to get the costume to fit any female base figure? I also get an error message when I try to use the Pose included in the product. I've had the problem with another product in the past (and had no product support and which turned out to be a Poser product) which is why I've been away from Daz Studio for  while.
Many thanks,
Dale
894 x 677 - 153K
896 x 835 - 174K
Post edited by Earth Balm on
  • SixDsSixDs Posts: 2,384
    Clothing designed specifically for Genesis 3 Female will not automatically work with earlier female figures. There may be workarounds available, but the results are never going to be guaranteed. Having said that, the outfit certainly should work with G3F. Is the result that is shown in the image you have provided the way the garments load, or is that after the pose has been applied? I don't have that particular item, so I can't test it, but it should autofit to the default G3F and pose pretty well.
  • scorpioscorpio Posts: 8,534
    Your image looks as if you might be loading the original Genesis not Genesis 3 Female figure.
  • Thanks SixDs and scorpio for your replies. I cannot find the Genesis 3 female figure in my Genesis 3 starter content library though I can find the Genesis 3 male figure. In the past I've used the Victoria and Michael 4 models so I confess, I'm ignorant of most features of the Genesis 3 models. Could you please help me to locate the Genesis 3 female base model?
    Thanks for your time and help,
    Dale
  • Problem solved. I had no Genesis 3 female content (for whatever reason). I uninstalled the Genesis 3 content and re-installed, now the female figure is there and the costume pops straight on.
    Thanks for the help.
    Dale
