how do I save a location on the grid as a preset?
Hello - I have a scene prop that is loading way off the grid. Is there a shortcut to getting it to the center of the grid  Its a parc from 'old town bordeaux' and it moves slow as I am trying to move it back to the grid so thought there might be a quicker way.
thank you
  • TheKDTheKD Posts: 2,711
    In parameter tab, set translate x y and z to 0 should bring most objects to origin.
  • thanks Ill try that!
  • Richard HaseltineRichard Haseltine Posts: 111,371
    edited April 2017
    If that doesn't work (if the item is modelled off-centre) create a new null (Create>New Null), select it, then select the thing you want to centre. Open the Align pane, set the X and Z axis options to Align Centres, and click the Apply button.
