Scene vs Scene Subset
I got some good answers for how to handle large scenes in a recent thread but am a little unclear about one thing. One can merge one scene into another (which would help to combine elements in a large scene), so what extra utility does saving something as a Scene Subset give you? In what situations would you use one versus the other?
  • TooncesToonces Posts: 919
    I wasn't aware you could merge scenes. Interesting.
    Still I'd use a subset since that's what it's designed for (saving a subset and merging later). Plus it's more specific. You pick exactly what you want in the subset.
    With a scene, it saves everything, including render settings. Often when I merge, I don't want the render settings to get altered.
    Finally if you are viewing it in smart content or content library, double clicking on a scene will load it by default (not merge). Double clicking on a set will merge it into the current scene by default.
  • nicsttnicstt Posts: 11,715
    You can pretty much merge anything, or so it looks like; you'll get told if something can't be done.
    Although, sometimes part of a merge just won't happen.
    If you save a full scene and merge it than the items in the scene will be merged, but certain aspects related to render settings (i've noticed) do not.
  • Richard HaseltineRichard Haseltine Posts: 111,359
    The main difference for loading is the default behaviour - double-click a Scene and it loads inplace of the current scene, asking if you wish to save any changes, double-click a Scene Subset and it merges.
  • Silent WinterSilent Winter Posts: 3,950
    When saving a scene-subset, can't you choose which parts to save?  So if you've got a busy scene and want to save just part of it out for use elsewhere, you could save it as a subset without having to delete bits.
    Correct. You can check which objects you want to save.
    I also like it for saving created figures. I suppose there is always saving as 'character preset', but subset is so generic, you can use it for lots of purposes.
