SketchUp imports
I imported an obj from sketchup. The MTL file is located in the same directory, but the obj is white (no materials) in daz3d. There are no textures. The MTL file just contains the colors. The mtl and obj file are in same folder and named the same (except for extension). I'm guessing Daz isn't compatible with these types of mtl files? See attached example.
433 x 459 - 12K
  • tring01tring01 Posts: 305
    The workflow I use with Sketchup assets is to export them as a Collada file, import the Collada into Blender, then finally export from Blender as an .obj.
  • TooncesToonces Posts: 919
    That's good to know! I should've mentioned I downloaded this as a free model. I'm not actually a scketchup user myself.
  • GranvilleGranville Posts: 702
    If the materials are just colors, you will have to recreate them by adding typing in the color values into the diffuse channels on the surface tab.
    Got it. Thanks!
