Hand poses Genesis 3 male. to dial or not to dial?
https://www.daz3d.com/handz-for-genesis-3-male-s
Anyone know if these hand poses work with dials, or do I have to click on them individually in the smart pane to apply...
  • TheKDTheKD Posts: 2,711
    Unless I screwed up my archiving of it, it's just clicky poses only. No data folder in my archive at least.
  • Griffin AvidGriffin Avid Posts: 3,884
    Damn. Thanks for the heads up,
    The good news is, the dials I already have sorta work to move from the fixed pose to the new pose.....
    I just need to remember to put THESE poses in first an then morph away from them.....
    So I want to buy this product too. It is posing the hand bones individually or is you using those entire hand sliders poses in the Posing tab that seem to ignore the setting the bones in the hand to what they should be if you created the hand poses posing the individual hand bones instead of the entire hand pose slider?
    That's sort of a contorted question does it make sense?
    Crud, it is only for Genesis 3 Males!
  • Fragg1960Fragg1960 Posts: 363
    I bought these hand poses (I buy a lot of hand poses).  Haven't had a chance to play with these yet, but they do look pretty good.
    The true test for any pose set are poses where the hand is clenched or hand is holding a gun.  In most commercial packages, the fingers for those poses always look wrong--never realistic enough--even after adjusting them manually (which you always have to do when the model is gripping something).
    A better test would be to with a knife and fork or a spoon.
  • scorpioscorpio Posts: 8,533
    They should work on G3F without much of a problem.
    Thanks
