why is my properties preset not saving the morph dial?
I have a pose and a morph applied to the base model.
I save a properties preset and chose my respective nodes for the morph and the pose.
I open a new file and load the model, then merge file and choose my saved preset file.
The pose loads as expected, but the morph does not.
Drilling down to my custom morph, I see it is not there.
I'm stumped. How do I load a custom morph dial reliably into a new scene?
What type is it set to, in Parameter Settings (via the gear on the slider)?
Most of case, save as preset can not save morph geometry values. you need to save your custom morph as morph assets, then property or shape or character preset
can load those morph with saved value.
or you can save it as subset with your custom morph (or saved aa scene), but nowdays it is not recommended much.
you may better if you often use the morph , just save it as morph asset first.
Kitakordedaz is correct. Saving the preset without saving the morph will lead you to the situation you speak of. (I speak from experience. :) )
Here is a hopefully helpful guide that may answer some questions for you too.
https://www.daz3d.com/forums/discussion/6483/tutorial-creating-a-genesis-g2f-g2m-g3m-g3m-full-body-morph-for-daz-studio-pro-4-6-by-rkane-1/p1
