Grid disappears
Hi all; When I start DS, the grid shows, then all the sudden diappears. Is there a fix for that? Thanks
  • algovincianalgovincian Posts: 2,696
    Click on the viewport options menu (4 horizontal bars in the upper right-hand corner of the viewport) and make sure "Show Floor" is checked.
    Hope this helps.
    - Greg
  • Richard HaseltineRichard Haseltine Posts: 111,380
    Showing briefly and then vanishing sounds like the viewport is using nVidia Iray preview mode, set by the button to the right of the camera/view picker at to[p-right of the viewport. It shows the OpenGL preview while preparing, with the griud, then switches toIray, without
  • Hi Greg.. I checked and it was set to show floor.. but that was still helpful as everyday I discover more about all these settings :o) Richard, I am not sure of what that is..but if you recall awhile back I tweaked the views..as to make it mostly white font on black BG due to eyesight isues.. I swtiched though to another layout and it reappeared. To be honest I am not really overly impressed by all the Iray hype anyways..thinking seriously about switching back to the ATI / AMD card.. The nVidia card is ok in Daz..but seems it causes havoc in some other applications such as my Xfinity player where it crashes a lot. Hopefully Daz in the future will come up with a renderer that is well rounded for both nVidia and ATI..
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,510
    have you got a second pci slot?
    if so put your nvidia card in that  and manually select it in D|S preferences.
    other apps and your monitors will pretty much ignore it unless specifically set, your PC will prob put a warninng message about incompatibility you can close up everytime you start up but otherwise is ok.
    Make sure you have a driver for both.
