Problem with transfer utitlity
I'm trying to use the transfer utility to create a conforming clothing for Genesis. When I import the OBJ to Daz, it doesn't come in centered, so I have to reposition the object so that it fits genesis correctly. After that, I use the transfer utility and everything works the way it should, except the object reverts back to it's original position. It's still conformed to the Genesis figure, it just doesn't fit into place. Anyone know what's going on?
  • Richard HaseltineRichard Haseltine Posts: 111,917
    The Transfer Utility ignores local transforms, so your adjustments are not being taken into account. If the model fitted Genesis in your modelling application then that suggests the import settings are wrong - you need to use the preset for importing the OBJ that you used for exporting Genesis to model around.
