Turn shadows off on multiple objects with less clicks?
I have a scene with like 100 objects. Please tell me there's a way to turn shadow casting off on all those objects quickly in very few clicks and I don't have to go through every single object and do it in 100 clicks.
  • Richard HaseltineRichard Haseltine Posts: 111,875
    Selecting all the objects will take most of the clicks - if they are all together in the Scene pane listing then you can click the first, shift-click the last to select all of them. Then use the Cast Shadows button in Parameters. Do bear in mind that this setting doesn't affect Iray.
  • ColemanRughColemanRugh Posts: 511
    You are badass, Richard! Thanks so much!! Using 3Delight - worked perfectly. Thanks a lot!!
