Rendering freezes my computer
As of last week, every time I try to render, my computer freezes on me.  I am wondering if anyone else is having this problem, and was wondering if there was an update that could have affected rendering?
  • Richard HaseltineRichard Haseltine Posts: 111,890
    My suspicion would be a hardware issue, such as heat, rather than a DS-specific problem.
  • ToborTobor Posts: 2,300
    I think I'd see if there was a "stealth" upgrade to your graphics driver. There are some graphics card utilities -- e.g. the nVidia GeForce Experience -- that can be set to automatically apply new drivers as they come out.
  • marblemarble Posts: 7,500
    I always switch off the GeForce Experience option in the custom install settings (along with the 3D VR stuff) - I don't play games on this PC so I stick with the basics.
  • nicsttnicstt Posts: 11,715
    Download a benchmark; see if it is something that happens when pushing the system towards its max; if the freezes don't happen then you have some info.
    Probably hunting starts with deciding if what you're seeing is a problem, or a symptom.
    ... Just because it's causing you a problem, doesn't make it the problem.
  • AndySAndyS Posts: 1,449
    Freeze? - mine too.
    wink almost.
    As you see, while rendering I'm still able to post here. OK - with some shorter or larger interruptions. But that's normal for CPU at 100%.
  • there's a tiny program called "BES – Battle Encoder Shirase" which will limit how much of your cpu a program can take...
    I only give Daz 75% access which actually let's me do other things while rendering...
    I started using it back when I had an i7 920
    http://mion.faireal.net/BES/
  • FishtalesFishtales Posts: 6,238
    I open Task Manager, right click on the DAZ Studio process and set its priority to Below Normal. Or if you have a multicore processor set Studio to only use some of them. Mine is four core and I sometimes set Studio to only use three leaving one spare for other things.
