Genisis Evolution: morph bundle not showing in 4.5
I have uninstalled it and reinstalled it and it still doesnt show up
Where are you looking? Where are you installing it to? You will find them in the Parameters pane by selecting Geneisis.
The readme file says :
Double post, no idea how that happened. :red:
Did you recently upgrade to 4.5 from 4.0?
If so, did you reset the download for the morphs?
Im looking with the rest of the basic morphs in the parameters pain. Im in stalling then eith the rest of Genesis, its the only place it will let me.
On the Product Page, it tells you what is included in the Body Morphs package, a few of them are listed below:
If I go the the Parameters pane, with Genesis selected in the Scene pane, then use the search function for 'Cheeks Define', you will see that DS4.5 finds it before I am finished typing. I know they are all there because I can find them with the Search function at the top of the Parameters pane.
These morph files were updated last year, but if you have recenlty downloaded them, they should be the correct versions. The Body morphs are v1.4, and the Head motphs are v1.5 (in the file name)
When installing these, make sure that the My Library folder is the last folder in the install Path. In other words, install ALL content into the My Library folder, and the installer will put it into the correct place. Don't install to My Library/People or some otherr sub-folder, just My Library.
Can you try that and get back to me. I really want to get these working for you.
Re-set your downloads for the morphs. I had the same issue, and I didn't also didn't know that it was updated to work in DS4.5.
