Somehow closed the "shaping" pane and can't reopen
Hi all,
  Just like the title says, I was exploring Studio 4.9 pro and accidentally hit the "close pane" button and my whole "shaping" tab disappeared.  How do I get it back?  I'm stuck because all the figures I've played with rely heavily on customizing the figure's bust, build etc.   Any help would be appreciated!
Thanks!!!
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Window>Panes(Tabs)>Shaping
  • Hi Thank You!  I can alter the figures now by opening that window.  Would you by chance happen to know how to return the tab to it's original position.  In other words, before it was a simply a tab like the pose controls.  How can I get it back there?
    thank you for your help!
  • You should be able to click on the pane name (Shaping) and drag it back into position.
    Don't forget, everything in the Shaping pane is also in the Parameters pane. It's just a bit more cluttered, because the Parameters pane groups together everything in Shaping, Posing and a few other panes.
    You can also, which I tend to forget, right-click in a blank area of an existing pane group and select Add Pane (Tab)>panename. That dos assume there is a blank area next to the tabs, however.
