True Ambience Black Objects
Hey all!
Does anyone know how to stop objects turning black when using True Ambience?
It just happens sometimes and I'm not sure what causes it!
  • HoroHoro Posts: 11,738
    edited April 2017
    M Sconty - difficult to answer without more information. Try this:  Disable Focused Scattering and enable Scattering Correction (and Reflection Correction) and see if it helps (speaking Bryce 7.1, not 6.1).
    Post edited by Horo on
  • M ScontiM Sconti Posts: 2
    I'll give that a try, thank you Horo!
    edited April 2017
    Sorry for the double post.  I can't delete it.
    Post edited by M Sconti on
  • Rashad CarterRashad Carter Posts: 1,832
    edited April 2017
    You may be running into inverted normals. It often happens when using meshes collapsed from boolean operations. Try exporting the object as a .obj and re-import and then try to replace it into the scene into the desired position. It's more of a boolean problem than a True Ambience issue.
    Post edited by Rashad Carter on
    Thank you, Rashad.  It was indeed due to inverted normals, and is working fine now yes
