quick keyframing question, probably simple
Noved1
when i do short animations using the keyframing method, i am able to go to the start of the animation, press "memorize figure pose" then go to the end, and press "restore figure pose" in a keyframe. and that makes a loop....but my problem is that the loop is not very smooth, it is kind of jagged when looping and playing over again. so is there a better method to loop animations? or maybe a few tips on how to make the loop smoother?
Could be a few issues...
One, if the end of your loop sequence is quite different from the start then make sure you have a few frames between your last key frame of the loop sequence and the actual last key frame (i.e. the one that matches the first key frame of the sequence). This will give Daz Studio some frames to transition between the end of the loop key frame back to the start of the loop key frame.
Another possibility is that the sequence looks rough because you have not rendered it.
