Geometry Editor - Vertex Display Size
Simple question, with a hopefully simple answer:
Is there any way to adjust the size of the red/yellow dot that appears around a selected vertex in the geometry editor?
It's huge by default, and makes it quite hard to accurately select vertices in dense areas of the mesh.  Google fu was no help.  Thanks!
  • Richard HaseltineRichard Haseltine Posts: 112,037
    I thought there was but I'm not seeing it now.
    edited March 2017
    It is not perfect answer, but you can try node weight map brush tool > geometry selection mode. with vertex selection.
    the selection tool in node weight map brush can adjust dot size. then you can keep the selection, between those two different tool by change tool (short cut, or meny icon)
    But the dot size not actuall gloval prameter size, then it easy change when you change view with Zoom .  and there is no way to set point under <1.00 value.
    1033 x 800 - 114K
    1202 x 815 - 138K
    Post edited by kitakoredaz on
    Then, I recommend use Focal zoom (R drug) and Dolly zoom (L drug)  dombination, adjust view port selection dot size.
    to make selection dot small in view, L drug and Dolly zoom, then use R durg to zoom out.
    to make dot large,  L drug and Dolly zoom out, then use R drug to zoom in.
