Is there a way to see which shader is currently applied to object?
Hi All,
In Daz, is there a way to see which shader is currently applied to object? Thanks.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Shaders are applied to surfaces rather than objects - an object may have multiple surfaces. To see which shader is applied to a surface you need to select the surface (most easily with the Surface Selection tool or using the list in the Editor tab of the Surfaces pane) and then look at the top-left corner of the Surfaces pane's Editor tab.
  • Thanks, Richard!
