ISO: Ground level temple/tomb entrance...
MJ007MJ007 Posts: 1,718
Preferably in a sand/plains environment and the cheaper the better.  Any and all suggestions welcomed.
-MJ
  • MJ007MJ007 Posts: 1,718
    edited March 2017
    Nothing like this.  Im looking for a ground level entrance to an underground tomb or crpt.  Like what you may find on an archelogical dig to some lost underground tomb/crypt.  i have something else in mind for the tomb itself.
    EDIT:  Something like the image attached.
    -MJ
    480 x 640 - 97K
    Post edited by MJ007 on
    edited March 2017
    This is exactly what im looking for!  Is there anything cheaper like this "out there"?  Anything  in PC+?
    -MJ
  • Charlie JudgeCharlie Judge Posts: 13,661
    edited March 2017
    Could you work with a mine entrance? This one is free: http://www.freewebs.com/mapps/downloads6.htm scroll about 2/3s of the way down the page
    Not eactly what you are looking for but there is also this in PC+ : https://www.daz3d.com/forgotten-tunnel-entrance
    Post edited by Charlie Judge on
    Nah,  it really needs to be built into the ground.
    -MJ
    edited March 2017
    nattaruk said:
    This is moreso the tomb itself, which i already have a set in mind for.  I need the exterior entrance to the tomb that will be set in desert-like environment.
    -MJ
  • FSMCDesignsFSMCDesigns Posts: 12,858
    -MJ
    This would be fairly easy to create in DS if you have any temple ruins. Create a new primitive in DS, a plane with a decent density. Apply a deformer to the area where you want there to be a hole. Create the hole with the deformer. Then add more larger deformers if needed to make the hillside rolling. Add the ruins from any addon around the hole you created and instant intrance.
    That explanation just gave me a headache as ive never done anything with deformers... but i also dont own any temple ruins products anyway.
    -MJ
    LOL, sorry. I use them often, so that are just basic tools for me. Hope you get it figured out.
    That dungeon entrance product is perfect in almost every way, so im not going to stress over it any further.  Just gonna stick it in my WL and hope for a good sale on it soon.
    Thanks everyone and a extra thanks to you Rich!
    -MJ
  • FishtalesFishtales Posts: 6,237
    A bit late but what about Atlandia Temple. Remove the steps and lower it into the ground.
    I really need the entrance opening to be parallel with the ground.
    -MJ
  • dragotxdragotx Posts: 1,149
    -MJ
    If you're not doing a long shot from outside through into the tomb you could rotate the Atlandia Temple 90 degrees so it's entrance is parallel to the ground
    edited March 2017
    dragotx said:
    -MJ
    But the stairs would also rotate 90 degrees and i couldnt show the people ascending into the tomb.  Even though the Atlantida Temple is cheaper, the "Dungeon Entrance" product just works all around better.  Just going to wait for a good sale as long as time permits.
    -MJ
    MJ007 said:
    dragotx said:
    -MJ
    -MJ
    I'll try and remember to check when I get home tonight and see if the stairs can be hidden on the temple,  Although I do like the Dungeon Entrance better for what you've said you want to do.
    dragotx said:
    -MJ
    Im just surprised there is absolutely nothing else like it. Ive been looking for something like this for weeks using various keywords and found nothing.  Well, i found something close by Meshbox, but from the promos I couldnt tell if the stairway was on the ground or on top of a building structure.  But other than that? Nothing.
    -MJ
    edited March 2017
    -MJ
    Like this?
    Click on image for full size.
    1496 x 997 - 1M
    Post edited by Fishtales on
    No, like one "laying" on top of the other.
    -MJ
    Now I see, you have changed the original image in your first post.
    Yes,  it kinda didnt accurately describe what i was looking for.
    -MJ
