Can not import the fbx file.
Can not import the fbx file. When I do this, a window appears quickly and the window disappears and the model does not appear in the 3D window.
  • Richard HaseltineRichard Haseltine Posts: 111,332
    What FBX file? Which application - Daz Studio?
  • Yes. Daz Studio.
    And what FBX file? If it's a freebie, a link, if it's something you've made yourself, at least the application you used to make it. People do import FBX files, but it's a format with a lot of variations.
  • On other computers it is imported.
    By Daz Studio? Or by other software? We really need more information if we are to give any help.
  • The man who gives this model, says that he is loaded in the DAZ studio. Can you give me a standard fbx model so I can check it? Or send this model to you?
    What model is it?
    One of the problems with FBX is the vast number of versions...plus there is a binary and ASCII version for each of them.  Studio only handles a small subset of the variants.
  • alexcov2000alexcov2000 Posts: 9
    edited March 2017
    The problem is fixed.
    Post edited by alexcov2000 on
  • Having the same problem of not being able to import a .fbx file from the newly revised Adobe Mixamo.
    Exported G2 male from daz 4.9 to apply animation in Mixamo..... downloaded fbx with skins, and when importing back into Daz a quick dialog box appears and leaves before I can take any action.
    is it a setting in Daz?
  • The problem is fixed.
    It would be nice if you could tell what you did to fix this.
    I have the same issue here. I was able to import a specific fbx with animations which I exported from MotionBuilder. The import was working and the animation was playing.
    But out of a sudden and for no reason visible to me that exact same FBX file could not be imported again. The log file shows that the file was imported and no error was given out.
    However as the OP wrote "a window appears quickly and the window disappears and the model does not appear in the 3D window."
    This is strange and I really would like to know how this was fixed.
    Same problem here, I don't know how to solve this... does someone have an idea ?
  • same issue here
    can no one  fix this problem?
    hey mate,could you please tell me how you solve this problems?
