DAZ 4.5: item "fit to" character
starbuckstarbuck Posts: 0
Up through D/S 4.0 under the pose tab there has been a "fit to " to make an item fit to a character. In DAZ 4.5 I can't find it. As an example I loaded the Biker Boots from the Bodysuit expansion. I had V4 selected before loading the boots. As usual, they don't fit onto her feet. I used to go to the parameters tab, scroll down to Misc, and click "Fit To ___" to make the item fit to V4. In daz 4.5 I can't find it.
  • BejaymacBejaymac Posts: 2,002
    It's there in the current build for me, so it might be an interface issue on your end that's hiding it, however you don't need to go into the Parameters tab to "Fit to", just right click the object in the viewport and you'll find it in that menu, or you can just "drag & drop" it from the content library onto your figure in the viewport.
  • starbuckstarbuck Posts: 0
    Thank you, that worked. It seems that a lot has changed, even from 4.0. Without a manual to refer to, it is hard to keep up with all the changes.
