Scene Subsets no longer load textures.
I think I screwed up, and I doubt I can fix this, but I wanted to ask.
I was trying to make my file structure make sense, and I realized that I had a ton of duplicate content in a folder in Daz3d/My Library/Content that was duplicating things at Daz3d/My Library.  So I moved everything from  Daz3d/My Library/Content up one level to Daz3d/My Library.  Now I'm in a position where none of my Presets or Scene Subsets will load the associated textures on the models.
I'm wondering if there's a way to change my Content Directories so that those files can be found, or if those are static links, and not relative paths.
  • Richard HaseltineRichard Haseltine Posts: 112,037
    The problem will be that the relative path in the Saved file will probably include the Content folder. I assume you are getting missing file errors? You could batch edit your saves to remove /Content from all of the paths - but that is a bit risky (I'm not sure there won't be legitimate examples of that string) and fiddly (you'd probably need to uncompress all of the files first, then edit them with a batch text editor). The other option is to fix them as you need them and resave - you should need to fix texture references only once per file, then DS will apply the new location to all of the other file references in that item.
