How to reset Categories in DAZ
I've categorized some of my content but now categorize it differently. Anyone know how to reset the Categories for the content?
there seems many way,,
if I were you,, work on
content library>categories> sub categories to organize categories.
first make new sub categories under the root categories if they are not ,
then copy and paste each assetes which you want to change from other category,
(you can use shift + right click or ctrl + right crick )to select assets in each categories)
after that delete the old category , by right clcik, which you need not .
(I believe you better not delete default > sub categories,, (categories by daz )
but you may hope to apply new sub catgory as default,, it seems no problem I think
or made new category out of default. )
or if you have not so many assets in your category,
jsut select asset by right click , then catgorize agaom . (need check off about old category)
after that delete the category from content library.
you naver lost your assets, from your directory just remove and change category.^^
