Face Mat Issue..
I'm not sure if it's supposed to happen like that, but when I add the face mat to my model the face turns a weird color. Anyone have info on why it does this or how to fix it? Model is Victoria 7 and program is DAZ3d. I am using the iray features, but it is happening with the regular ones as well. I attached a picture so you could see what I mean.
3838 x 2061 - 4M
  • Richard HaseltineRichard Haseltine Posts: 112,021
    Are you sure the rest of the figure is using the Iray skin settings?
  • Yeah, I specifically picked the iray.
  • SixDsSixDs Posts: 2,384
    It looks to me as though you have loaded Victoria 7, then applied the Adaline base material and then applied a default V7 face material to that. If that is what you have done, then the result is exactly what would be expected. You can either use one of the Adaline face/makeup options instead of the V7 one, or. alternatively, replace the base Adaline texture with the base V7 one.
  • I'll have to look into that. I don't think that's what I did, but it's possible.
