Aeon Soul product question?
So i have an older product from the Arey Soul days called Alice. Its a character morph. My question is, is there a way i can inject V4 clothing with the Alice morph so i can fit other products to the Alice figure?
  • LeanaLeana Posts: 13,667
    In DS you can use the "transfer active morphs" function:
    • load V4, inject Alice morphs
    • load your clothes, fit to your morphes V4
    • select the clothes in the scene, right-click in the viewport and select "Transfer active morphs" in the menu: matching morphs should be added to the clothes
    Another option is to use an utility like Dimension3D's Morphing Clothes
  • OMG Leana this works like a charm! thank you so so so so so much! I would have never kew about this feature!
  • it doesent seem to work on everything though, unless im doing it wrong lol
    It should work for all items fit to your figure, though the results may not be perfect, but won't work for props IIRC.
    Make sure you added the morph before the clothes though, it doesn't seem to work otherwise.
  • will it work if i load a character with a morph already injected?
  • Richard HaseltineRichard Haseltine Posts: 112,078
    Yes, Active Morphs means morphs that have a non-zero value - morphs that aren't in use won't be transferred.
