Can a Camera Preset turn off walls?
ScavengerScavenger Posts: 2,677
Apparantly, in Poser, you can set a Camera preset to also turn off walls that are in the way.
Can you do this in Daz?
I don't recall seeing a way in the actual sae dialogs, but could you combine the instructions in a camera preset and a properties preset into a signle duf file via text editor?
  • FrankTheTankFrankTheTank Posts: 1,624
    You could parent an iray section plane to a camera
  • marblemarble Posts: 7,500
    Are Section Panes scaleable? Or do they hide everything to one side of the plane no matter how big or small it is?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    The latter.
    Thanks - I thought I was missing a technique somehow.
  • ScavengerScavenger Posts: 2,677
    I m unfamiliar with Iray section planes.
    Create>New Iray Section Plane. It creates a plane, stuff on the near side (as it loads) is invisible to the camera and to lights, but you can tell it to clip lights in its parameters (which I think is more useful - it lets you see into an enclosed space without ruining the lighting or reflections).
