Remove delta from morph gradiation
You can remove parts of a figure from a morph.
Is there a way to 'feather' a vertices selection or otherwise soften the transition between 'affected by a morph' and 'not affected by a morph'?
I'm guessing no, not without pulling stuff into a model editor.
  • Richard HaseltineRichard Haseltine Posts: 112,037
    Not with the Geometry Editor option. If you export as OBJ and then load back with Morph Loader Pro you can atenuate the morph in various ways, including with a weight map (from a a DForm, or using one of the bone maps).
