Feet measurement lock
Hi,
i am working on 5 to 10 different bodies with different body measurements but i need to have the same feet measurement, size and shape from the ankle till the toe across all bodies, could you help us with solution that would help to fix it.
  • Richard HaseltineRichard Haseltine Posts: 112,021
    You could use Measure Metrics to monitor the size, but I'm not sure even using Figure Metrics would enable you to avoid chnages if the moprhs you use to modify other parts also affect the feet. You can subtract the feet from the morph, but the issue there would be gettng a smooth transition.
