Dynamic cloth simulation does not show in Realty 3D
The addition and simulation of a cloth object in 4.9 does not show up in the Reality 3D materials and of course, does not render out. Anyone have any ideas?
Post edited by davidcaputokeene on
If you're using the native Optitex system, did you freeze the simulation so that it converts to an animated pose for each frame? That might be what's causing the issue.
Thanks how does one do this?
If you go to the 'Dynamic Clothing' panel and click on the dropdown options (arrow and lines, usually at top right), there should be an option to freeze the simulation. After that you'll end up with a morph per frame, which chanegs with the animation playback. Not saying that's the issue solved, and bear in mind you'll lose the simulation setup, but you can save the dynamic properties under the main 'File' menu before you run 'freeze simulation'.
