How do I delete a Daz Connect item?
Hi, I'm a new user to Daz Studio, installed DS 4.9.3 Win 64b, installed some content via Daz Connect by mistake, now I want to delete it ... but how?
I've tried every pane I could find, R-clicking provides no delete option, the minus sign button in the Content Library tab is greyed out. Stuck! Any ideas?
Cheers,
Ian
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Right-click on the product and select Uninstall.
  • eeyuneeyun Posts: 53
    You'd think, but ...
    Ah! when you say "product" you mean the item in the alphabetical "Products" listing. Got it - thanks Richard! I went to Daz Connect listing... but right clicking on those icons doesn't give you an uninstall option.
    The Products tab in Smart Content should also work.
  • Leo LeeLeo Lee Posts: 197
    I have installed a script via Daz Connect and I can't uninstall it because it didn't show up in the Install pane.
    How can I uninstall it?
    If you find the product in Smart Content or the Products list and right-click Unisntall should be an option. Install is solely for that, it isn't for uninstall and won't show installed products at all.
    edited April 2017
    I can't find it in Smart Content. It's a script and only shows up in Content Library.
    Thanks for the info to uninstall Daz Connect items. I didn't know that.
    400 x 386 - 40K
    Post edited by Leo Lee on
    I got it! I unchecked "Filter by Context" in Smart Content and it showed up. =)
    Thanks Richard for your help.
    You can right-click on actual files, such as a script, and select Create Custom Action to add them to the Scripts menu - even if they are content. You can then use Window>Workspace>Customise to move them to other emnus if desired (I've created a Select menu which has some of my own scripts and the built-in commands, for example).
