Anyone know how to use Actual Tears?
This product includes documentation which says that you need to create a distant light, set it to specular only, and "angle it til you get the desired results"
I've wasted tons of time on this now, I can't get any result even remotely similar to the advertised possibility. The tears don't look liquid, and aren't reflective. Just a vaguely discolored spot really. I'm wondering if I need to change other light settings, or what?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Are you rendering in 3Delight or Iray? The specular-only light is a 3Delight thing.
  • edited March 2017
    Oh I see. I'm using iray actually. So is this just an outdated product then? Or is there a way to get good results in iray?
    Post edited by intrinsicanomaly_262dc77de2 on
    There have, I think, been a few threads on this set in Iray - I can't recall that anyone was able to get it working directly.
  • RuriRuri Posts: 50
    Maybe you can try this, manually apply the iray water or glass shader on the tears. Bump up the 'thickness', forgot the exact path, its the same menu as the smoothing modifier you apply on figures.
