Anastasia Outfit - Can you render the helmet without the horns?
GatorGator Posts: 1,320
Like the armor, I think I would prefer the helmet without the horns.  Is there an option without them, or can they be hidden without the helmet appearing to have holes in it?
https://www.daz3d.com/anastasia-outfit-for-genesis-3-female-s
  • TraceSLTraceSL Posts: 547
    Does not appear you can, the horns are not a sperate prop.
  • riftwitchriftwitch Posts: 1,439
    edited March 2017
    I see an expand morph for the horns; it might be possible to use that with a negative value to eliminate them. That doesn't always work, but sometimes it does.
    Post edited by riftwitch on
  • Oso3DOso3D Posts: 15,116
    IF the helmet is modeled as a complete shape in which the horns are embedded, then hiding the surface of the horns will work (if the surface isn't separate to begin with, it's fairly trivial to create a new horn surface with geometry editor).
    If not, then, well, boned.
