please Help Genesis3 + aniMate 2
Hi,
please help
What am I doing wrong ?
I try to animate a Genesis 3 char with aniMate 2... a very simple walk
Whatever I try the result is very strange
attached the video link:
video
thx,
  • Richard HaseltineRichard Haseltine Posts: 112,033
    Which figure was the AniBlock made for?
  • IvyIvy Posts: 7,165
    edited March 2017
    I can tell you right up front from experience genesis 3 is very difficult at best to work with in animation.   you need to have aniblocks that are made for Genesis 3, because it is not compatible with any other older daz characters & I have not had much luck using the pose and animation convertors myself that does not require still tweaking the conversion. . .the reason is that Genesis3 has a exotic mesh, which  is much different configuration than the older daz generation characters. so the mesh does not match up to the older mesh motions & will do weird things when you try to use those older motion files with it. And g3 will not use poser BVH motion files at all as where genesis 2 and genesis figures will with minor tweaking the feet and hands .
    I suggest you try a older figure and see if you ge the same results.   Good luck
    Post edited by Ivy on
