Where are the uber volume controls?
martinkeitel_e65f08430a
Hello. I'm trying to use Uber volume lighting. But I can't access the settings for the volume light. When the volume object is selected in the scene, the parameters tab doesn't show any controls. I suppose the controls should show somewhere according to the user guide at http://www.omnifreaker.com/index.php?title=UberVolume.
I tried both DS3 and 4.5.
First you need to parent the cone (or sphere) to a spot light. Then after that, apply one of the presets. Then to expose the controls, there should be, in the Scene pane, another item, attached to the spot light, called SpotLight Volume. Select that and then look under Surfaces...your controls should be there.
Okay thanks. Didn't realice it's in the surfaces tab! :)
