Resource Error in Content Library Categories
Hello,
I have the latest DAZ release on Windows 8 (64 bit) installed (clean install/no updated). I am having problems categorizing my stuff. I have data on a local drive and a network drive and the paths are setup correctly in the content library manager.
The problem is, if i categorize an item and navigate in the content library via categories, newly catagorized items all have that yellow exclamation mark:Resource Error: File does not exist. But the location shown is all right. It seems to ba a problem with those items on the network drive.
If I hover over that item in the content manager, the file path seems to be a mix of the DAZ Studio installation directory and the full (correct) file path (e.g. C:/Program Files/DAZ3D/DAZStudio4/NETWORK-DRIVE/../../..
I tried right clicking and set the base path but it doesn't seem to have any effect. I assume the base bath should be the same as set up in the content library manager, right?
Any ideas what I am doing wrong?
TIA,
Alex
Fixed!
The problem was that in the Content Directory Manager I used relative paths for the network drive (\\network\...\..). I changed it to absolute paths (u:/../../) which solved the problem.
