Shadows without a ground?
Hi, I am trying to achieve similar shadows than the ones I get when I use Dome environment but when using scene only. I know I can set Draw Ground to ON, but that doesn't seem to cast the shadows from Point Lines or Linear Point Lines. After much testing, I ended up finding someone here on the forums sharing some experiments showing the same results. Also, when I add a plane then I can see the shadows.
My question is, is there anything I can do to the plane to make it "invisible" and only cast the shadows as the ground would have?
I am quite new in here so excuse me if this is very basic.
Thanks a lot!
  • RobotHeadArtRobotHeadArt Posts: 917
    edited March 2017
    This tutorial shows how to create an invisible plane that catches shadows
    Post edited by RobotHeadArt on
  • That is exactly what I needed, thanks a lot!
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Note that a linear point light is just a point light in Iray - you can't set arbitrary fall-off and start/end points in Iray, which is what the linear light offers.
