Alpha channel not working with displacement map
Hello,
I'm trying to create a single hair. In photoshop i've created the single hair with the color white (visiable by daz) and have created the rest that I don't want to see in black (not visible in Daz).  However when I apply this image to a plane in Daz under the displacement map nothing happens and all I see after the render is the whole plane visible and in white.  I'm not sure why my alpha channel isn't working.  According to everything I read the color black should be transparent while the color white is visible.  Am I missing a setting somewhere?
Thanks!
354 x 364 - 35K
1485 x 1194 - 813K
  • glaseyeglaseye Posts: 1,312
    edited March 2017
    Transparency is handled by cut-out opacity, not displacement
    300 x 300 - 51K
    Post edited by glaseye on
  • kinkyhemp2611kinkyhemp2611 Posts: 14
    edited March 2017
    Thanks glaseye.   For some reason the cutout opacity isn't showing up in my surfaces tab like all the tutorials suggest.  Any suggestions?
    Thanks
    453 x 787 - 109K
    Post edited by kinkyhemp2611 on
  • scorpioscorpio Posts: 8,533
    edited March 2017
    What shader do you have applied DS default or Iray Uber or something else, cutout opacity is  Iray Uber DS default has Opacity Strength
    Post edited by scorpio on
  • Scorpio I have the Iray Uber shader applied.
    Thanks
    Your attached image shows the 3delight shader tree, not the iray one, and it is visible as the 'opacity strength' setting there.
    In the iray shader, the 'Cutout Opacity' setting is usually just above the Displacement Strenght' setting if you have the 'Iray uber base' shader applied from the 'Shader Presets - Iray - DAZ Uber' tab/menu
  • That worked!  Thanks glaseye!
