Quick question about Stonemason's Chinatown
Hi guys
How do I turn on the Light bulbs / Neon signs in Stonemason's Chinatown scene for nighttime render , as shown in the product page ?
Thank you for your answer in advance smiley
  • Richard HaseltineRichard Haseltine Posts: 112,021
    Iray or 3delight?
  • Hello Richard
     Iray cool
    You need to select the surfaces that should be lit (most readily with the Surface Selection Tool) and apply the Emissive preset (in Shader Presets>Iray>uber)- hold down the ctrl key (cmd for Mac) while applying the preset and in the dialogue that opens choose the Ignore option for Maps, this will leave the text and other elements in palce on the signs that are more than a flat colour. In the Surfaces pane adjust the luminance as required, and perhaps the colour temperature. Here I just added the emissive sahder to the two blcoks of Chinese writing, the bulbs, and the restaurant sign, upped the luminance on the two sets of Chinese writing, and added a point-light to the shop interior (also upping its luminance), then turned the film ISO in Render Settings to 800. It needs more light, both for effect and to improve convergence (this wasan't quite done, and had taken eleven minutes on a GTX 750Ti card), but shows the approach.
    1000 x 1000 - 526K
  • And for 3Delight users, how would we light Chinatown up?
  • You need to select the surfaces that should be lit (most readily with the Surface Selection Tool) and apply the Emissive preset (in Shader Presets>Iray>uber)- hold down the ctrl key (cmd for Mac) while applying the preset and in the dialogue that opens choose the Ignore option for Maps, this will leave the text and other elements in palce on the signs that are more than a flat colour. In the Surfaces pane adjust the luminance as required, and perhaps the colour temperature. Here I just added the emissive sahder to the two blcoks of Chinese writing, the bulbs, and the restaurant sign, upped the luminance on the two sets of Chinese writing, and added a point-light to the shop interior (also upping its luminance), then turned the film ISO in Render Settings to 800. It needs more light, both for effect and to improve convergence (this wasan't quite done, and had taken eleven minutes on a GTX 750Ti card), but shows the approach.
    I followed this instruction and It worked perfectly , Thank you so much for your time Sir , Appreciate it yes
  • SzarkSzark Posts: 10,634
    same thing via surfaces and apply Uber Area Light shader see my tutorial for more info http://www.daz3d.com/forums/discussion/14536/tutorial-uber-area-lighting-the-basics/p1
