Help please! No mouse pointer in daz screen!
What do I need to press to go back to normality? I pressed something and now I can't see the mouse pointer in daz screen
Thank you very much
    This sounds like an old problem that has plagued Daz Studio for years. I know of no solution other than to quit Daz Studio and start it up again. If you can move the mouse around without a visible cursor, you may be able to see the close box highlight and quit that way. Otherwise, you'll have to terminate the process. I hope someone else comes along with a better solution, if one has been found recently.
  • Roman_K2Roman_K2 Posts: 1,277
    Wow.
  • SixDsSixDs Posts: 2,384
    Keyboard shortcuts. If you simply want to exit DAZ Studio, you can simply close it from your taskbar, or Task Manager. Or you can close it from within DAZ Studio by using Alt+F to access the dropdown list of options. The keyboard shortcuts are then shown adjacent to the commands:If you want to save your scene prior to quitting, then use Ctrl+S; if you want to SaveAs, then Ctrl+Shift+S: or if you simply want to close DAZ Studio, use Ctrl+Q. Although most people have become conditioned to using their mouse and most applications are designed for that, keyboard shortcuts usually also exist for most major functions and navigation.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,830
    it used to be if you could get it to the preview window tab the one with cameras top, bottom etc and click in there it worked again
    If you mean the various multiview viewport options, Wendy, you can access those easily with just your keyboard, as well. If you look at the menu headers for DAZ Studio, you'll notice that each has one underlined letter. If you type Alt+that underlined letter, it opens that menu. You can then navigate using the "arrow keys" on your keyboard. So to access the viewport options, you would type Alt+W, then down arrow to viewports, then right arrow and down arrow to the option wanted and hit return.
