Exporting V4.2 CR2 Error
Angel_2232633Angel_2232633 Posts: 1,204
I get this strange error then I export. I provided my settings.
I'm trying to use Blacksmith3D Texture Converter
424 x 114 - 17K
567 x 495 - 42K
Post edited by Angel_2232633 on
  • Richard HaseltineRichard Haseltine Posts: 112,089
    That file is part of the base Poser content so it isn't exported from DS, and I think DS has its own version (either that or it skips then references, I can't recall). Can Blacksmit not use the original V4 CR2? Or have you made changes?
  • Angel_2232633Angel_2232633 Posts: 1,204
    I've never made changes. I don't own poser. I'll try other versions. I got it to work a few times... This is a new thing. Cause its worked before.
  • SixDsSixDs Posts: 2,384
    "I don't own poser"
    That isn't what Richard was referring to, Angel-Wings. He was referring to the fact that V4 files are all in Poser format.
    If you have not made any changes to the the V4.2 .cr2 file, I don't understand why you are attempting to export it from DAZ Studio, since it already exists within your content library. You should simply need to import it into Texture Transformer as the source .cr2, which will then be used to match up with the destination figure .cr2 for texture conversions. My understanding of the software is that a new conversion file will be created that can then be used for subsequent texture conversions between the two figures, although I don't use the application myself.
    edited March 2017
    SixDs, I'm exporting it for Blacksmith3D. Thats how it loads the V4...
  • TottallouTottallou Posts: 555
    I have done this for Blacksmith but on my export I do not have the box "Collect Files" checked as you don't need these  - I just retested and checking that box creates the error about the null.obj
