what to call skin material folder when using daz default shader?
Mistara
in The Commons
what to call material folder when using daz default shader?
it's not iray, not AoA. calling it 3de is vague, it could cover a few different styles.
it's for carrara, trying to make the skin shader load into carrara without the multiplier thing.
thanks
3DL Default?
DzD?
technically, Daz Default shader isn't MDL. so that leaves RSL?
and then there the luxus shader.
wonder if a luxus shader from ds, would translate the same settings to the carrara luxus?
