rendering-scene will not render past zero
I just loaded this great scene and as the image shows it will not finish rendering, does anyone have nay suggestions?
thanks
1802 x 871 - 649K
  • ToborTobor Posts: 2,300
    Lots of reflections will take longer to render. The floor is highly reflective, causing considerable additional rendering overhead. Depending on your machine, you may not see a progression for much longer than 4 minutes.
    If you're looking to cut rendering time down, find the Max Path Length control in the render panel, and adjust that from the defailt -1 (infinite) to about 7 or 8. This limits the ray bounces for reflections. Avoid going lower, or else other parts of your scene (like eyes) may not render properly.
  • dragotxdragotx Posts: 1,149
    thanks
    It's not unusual for my bigger scenes to take 10 minutes to show anything at all in the render window, and I'm on a beast.  Try giving it some more time and see how it does.
  • AndySAndyS Posts: 1,449
    If you're rendering without an nVidia GPU card, be happy to have a halfways noise-free result after 3 hours.
