Terradome in Octane
Now, as I now know, Terradome 3 only works in iray. Materials seem to be lacking when it comes to using the Octane Plugin. Is there a way to make TD3 work with Octane?
I know this is an old post but is in top results for search "Terradome 3 in Octane", so I will chime in here as well. I made a mix using dirt texture as the output for the overlaying texture and it behaves very similar if not the same as Terradome's native Blend. You would plug one set of textures (A) into one node and other one (B) in a second, I mixed them at 50% each, and then used dirt to output one I want to scatter above.
Each texture will need tiled at 20-30 tiles (0.02 texture scale or similar). Hope this helps someone, I'm attaching current look of my NGE and results with three different dirt shader values as snow :)
